Mikrotik - Набор правил Firewall
Как вариант можно попробовать такой набор правил:
/ip firewall filter
# INPUT
add chain=input connection-state=invalid action=drop comment="drop invalid connections"
add chain=input connection-state=related action=accept comment="allow related connections"
add chain=input connection-state=established action=accept comment="allow established connections"
# ext input
# Здесь можно добавить правила для проброса
# local input
add chain=input src-address=192.168.1.0/24 action=accept in-interface=!ether1-ext
# drop all other input
add chain=input action=drop comment="drop everything else"
# OUTPUT
add chain=output action=accept out-interface=ether1-ext comment="accept everything to internet"
add chain=output action=accept out-interface=!ether1-ext comment="accept everything to non internet"
add chain=output action=accept comment="accept everything"
# FORWARD
add chain=forward connection-state=invalid action=drop comment="drop invalid connections"
add chain=forward connection-state=established action=accept comment="allow already established connections"
add chain=forward connection-state=related action=accept comment="allow related connections"
add chain=forward src-address=0.0.0.0/8 action=drop
add chain=forward dst-address=0.0.0.0/8 action=drop
add chain=forward src-address=127.0.0.0/8 action=drop
add chain=forward dst-address=127.0.0.0/8 action=drop
add chain=forward src-address=224.0.0.0/3 action=drop
add chain=forward dst-address=224.0.0.0/3 action=drop
# (1) jumping
add chain=forward protocol=tcp action=jump jump-target=tcp
add chain=forward protocol=udp action=jump jump-target=udp
add chain=forward protocol=icmp action=jump jump-target=icmp
# (3) accept forward from local to internet
add chain=forward action=accept in-interface=!ether1-ext out-interface=ether1-ext
comment="accept from local to internet"
# (4) drop all other forward
add chain=forward action=drop comment="drop everything else"
# (2) deny some types common types
add chain=tcp protocol=tcp dst-port=69 action=drop comment="deny TFTP"
add chain=tcp protocol=tcp dst-port=111 action=drop comment="deny RPC portmapper"
add chain=tcp protocol=tcp dst-port=135 action=drop comment="deny RPC portmapper"
add chain=tcp protocol=tcp dst-port=137-139 action=drop comment="deny NBT"
add chain=tcp protocol=tcp dst-port=445 action=drop comment="deny cifs"
add chain=tcp protocol=tcp dst-port=2049 action=drop comment="deny NFS"
add chain=tcp protocol=tcp dst-port=12345-12346 action=drop comment="deny NetBus"
add chain=tcp protocol=tcp dst-port=20034 action=drop comment="deny NetBus"
add chain=tcp protocol=tcp dst-port=3133 action=drop comment="deny BackOriffice"
add chain=tcp protocol=tcp dst-port=67-68 action=drop comment="deny DHCP"
add chain=udp protocol=udp dst-port=69 action=drop comment="deny TFTP"
add chain=udp protocol=udp dst-port=111 action=drop comment="deny PRC portmapper"
add chain=udp protocol=udp dst-port=135 action=drop comment="deny PRC portmapper"
add chain=udp protocol=udp dst-port=137-139 action=drop comment="deny NBT"
add chain=udp protocol=udp dst-port=2049 action=drop comment="deny NFS"
add chain=udp protocol=udp dst-port=3133 action=drop comment="deny BackOriffice"
add chain=icmp protocol=icmp icmp-options=0:0 action=accept comment="echo reply"
add chain=icmp protocol=icmp icmp-options=3:0 action=accept comment="net unreachable"
add chain=icmp protocol=icmp icmp-options=3:1 action=accept comment="host unreachable"
add chain=icmp protocol=icmp icmp-options=3:4 action=accept comment="host unreachable fragmentation required"
add chain=icmp protocol=icmp icmp-options=4:0 action=accept comment="allow source quench"
add chain=icmp protocol=icmp icmp-options=8:0 action=accept comment="allow echo request"
add chain=icmp protocol=icmp icmp-options=11:0 action=accept comment="allow time exceed"
add chain=icmp protocol=icmp icmp-options=12:0 action=accept comment="allow parameter bad"
add chain=icmp action=drop comment="deny all other types"
# (5) drop all other forward
add chain=forward action=drop comment="drop (2) everything else"
Mikrotik - Набор правил Firewall (вариант 2)
Еще один актуальный, но до безобразия простой набор правил.
Разрешаем пинг роутера:
/ip firewall filter add chain=input action=accept protocol=icmp comment="Accept PING"
Разрешаем успешно установленные соединения:
/ip firewall filter add chain=input action=accept in-interface=ether1-ext connection-state=established comment="Accept established connections Mikrotik"
/ip firewall filter add chain=forward action=accept in-interface=ether1-ext connection-state=established comment="Accept established connections LAN"
Разрешаем родственные соединения:
/ip firewall filter add chain=input action=accept in-interface=ether1-ext connection-state=related comment="Accept related connections Mikrotik"
/ip firewall filter add chain=forward action=accept in-interface=ether1-ext connection-state=related comment="Accept related connections LAN"
Здесь можно добавить правила разрешающие для NAT и входящие
Запрещаем недействительные соединения:
/ip firewall filter add chain=input action=drop in-interface=ether1-ext connection-state=invalid comment="Drop invalid connections Mikrotik"
/ip firewall filter add chain=forward action=drop in-interface=ether1-ext connection-state=invalid comment="Drop invalid connections LAN"
Запрещаем все остальные input соединения:
/ip firewall filter add chain=input action=drop in-interface=ether1-ext comment="Drop all other input connections"
Разрешаем доступ в интернет из локальной сети:
/ip firewall filter add chain=forward action=accept src-address=192.168.1.0/24 comment="Access Internet From LAN"
Запрещаем все остальные forward соединения:
/ip firewall filter add chain=forward action=drop comment="Drop all other forward connections"
